Dynamic Interactivity Week 15
05/09/2019 at 23:54 • 0 comments- I reworked and changed my design a bit for the final submission.
- A part of the support holding the head collapsed.
- I improvised and attach the servo to rotate the head, onto a base in the box.
- The head is the attach onto the base, which is supported by the servo underneath it to rotate.
- After reworking, when a user is looking at the head from a certain direction, the face is then tracked, and the head will turn towards another direction to avoid direct contact (antisocial).
- When a user gets too close to the head, under 20 cm, the head will jerk in a 15 degree angle to avoid contact.
- A screaming sound will play when a user gets closer than 20 cm.
Dynamic Interactivity Week 14
05/06/2019 at 03:03 • 0 comments- I finished up on the all the coding needed for submission.
- I have moved on the final fabrication stage of my head model.
- I added putty fill-a to cover up the gaps in my model.
- I tested my installation to make sure it works well for submission.
Dynamic Interactivity Week 13
04/24/2019 at 12:49 • 0 comments- I properly put the whole head together.
- I added the stand and mechanism into the head to test it.
- I prepared for the beta test.
- But the whole stand collapsed.
Dynamic Interactivity Week 12
04/24/2019 at 12:47 • 0 comments- I experimented with different head stands to hold the overall shape of the head.
- I tried adjusting the position of the servos to make sure that they don't interfere with other wires which may affect the servos' rotations.
Dynamic Interactivity Week 11
04/24/2019 at 12:45 • 0 comments- I have completed putting the head parts together.
- I tested the coding with my arduino to make sure that it works properly.
- I planned on the design of the servo holders and and the overall stand of the head.
Dynamic Interactivity Week 10
04/24/2019 at 12:44 • 0 comments- I printed about 75% of the overall head parts and starting to the get the full overall shape of the head.
- I tested more servos and tried to think of other things that I can do using the servos which will benefit my head project.
Dynamic Interactivity Week 9
04/24/2019 at 12:42 • 0 comments- More head parts were printed for the project.
- I tried combining the parts using the rotary tool as well as glueing them together.
Dynamic Interactivity Week 8
04/24/2019 at 12:40 • 0 comments- I tried printing the servo holder for the head, and tried out different designs.
- I started printing out a few pieces of the overall head and try to piece it together.
Dynamic Interactivity Week 7
04/24/2019 at 12:39 • 0 comments- I printed out more 3D printed parts to test the overall structure and get an overall idea of how it will look like.
- I worked on the coding aspect of my project as well as trying to work on the servos.
Dynamic Interactivity Week 6
04/24/2019 at 12:32 • 0 comments- I further experimented with new 3D printed models.
- I tried different designs to get the ones I think suits my project the best.
- I printed a few test parts to get the overall structure.
