This week reworked my design a bit for final submission.
I add on the cotton on the circle, but the cotton can not stick on the circle. So, I use string to make a lot of cotton ball to help me stick on the circle.
I put the sensor in side the memories box.
so people stand inside the box, can feel the cloud become bigger and got lightning also have thunder sound.
This week i find out the circle can expand bigger but is hard to expanding, because the expanding circle too heavy become a bit bend and make the circle hard to expand.
And i was thinking try to add a big circle support at the bottom, can make the circle no bend.
This week i find out the expanding circle no really can see the expending. Because the expending is to litter and i try to make a extend stick when the cloud expanding can expand more.
This week i try 3d print a support to stick at motor and connect with cloud. The support need to stick at the motor and also need to can turn fishing line.
After using the thicker board is no easy to broke. and this week i worked on the coding for the motor can turn forward and reverse. I find this website is very helpful https://www.teachmemicro.com/use-l298n-motor-driver/# the table very easy to understand,
at the beginning i can't find where is the ENA. But after i ask Ron i know where is it just need to take out the small black cover.
