While my 3D model still printing, I was making a base to put my model. Before I confirm make the base, I try out many time to make sure the base is work and tall enough. After that I make it 10cm height and the width and long is 30cm.
After I done my motor part. I doing the MP3 and the sensor coding. At first the MP3 was going smoothly but after I combine all the code, the MP3 was come out so many problem. At last, I fix my MP3 problem but I still test it all the time to make sure it really can work.
I have learn how to soldering all the wire and connect it part by part. I ask Alden a lot about the coding and how it work. So I start my first part coding which is how to make my motor move.
I was decided to print the half body because I want user just focus on the half body. I cut my model into a part to print it. While my body was still printing I start my coding part.
I keep on adjust my model and test print. Sometime the model too big sometime it too small. when finally fix the size but the bending part in the model was hard to bend it. Finally I fix all the 3D print problem and start to print the model come out.
After my 3D human body done I cut a long hole from the leg to the butt. I cut it some part to test how it work when 3D print it. But at first I had fail because my leg is too small when it print it out.
I have test out three different pipe. First one because it got some curly inside so it hard to move. For the second pipe the inner is too small can't fix the pellet. So I choose the pipe which is diameter 1.7cm.
