wikitIDE: program arduino 101 visually
This is a derivative wikit program for you to control arduino 101 neuron A.I. function with simply drag and drop
Arduino 101 is a hardware powered by intel which could achieve A.I. by neuron learning. With this program, we can simply programming the most advanced A.I. with simple drag and drop in IPAD
1. zero wire + wikitIDE + arduino101
2.wikitIDE + arduino101
Why this project?
With 0-wire hardware and visual arduino 101 neuron programming, you can easily start your journey on A.I. with learning and category feature.
In this project, we would find a brand new way to make intelligent hardware including gesture recognition, environment monitoring, healthy program etc.
What is 0-wire hardware?
As the pic below, all modules are connected within bluetooth mesh to do the data transaction. This will eliminated the hardware distance limitation and make the sensor much self-contained.
What is neuron?
neuron, as my understanding, is kind of component where you can store vector and recognize vectors with specific algorithm
How about the visual program UI?
in hardware page, you can test all the modules in the network with simple click. all the data will directly show above the corresponding icon.
In software page, we are using flowchart
wikit zero wire quick start.pdf
detail procedure for visual A.I. programming with 0-wire kit
Adobe Portable Document Format - 322.32 kB - 10/15/2016 at 16:27
Preview
  • 1 × arduino101 an intel A.I. chip which also is compatible with arduino UNO
  • 1 × light sensor with BLE
  • 1 × mp6050 with BLE
  • 1 × th02 temperature sensor with BLE
  • 1 × switch with BLE
View all 6 components
View all 3 project logs
View all instructions
hongjieli wrote 10/17/2016 at 08:09 point
superb project! It helps beginners bring up idea in very short time.
minqi bao wrote 10/15/2016 at 01:33 point
hi, currently uno standalone cannot support if since we need bluetooth communication with iPAD. arduino101 happens to have this inside while all gpios are compatible with UNO.
ActualDragon wrote 10/14/2016 at 16:58 point
maybe try a easy visual coding program for uno?
