10cm-round-lamp.blendRound Lamp Blender filex-blender - 811.92 kB - 03/04/2019 at 23:19 |
rgb-lamp-10cm.stl10x4 cm rectangular Led Lightsla - 280.36 kB - 03/04/2019 at 23:18 |
rgb-lamp-10cm-top-Leds.stl10x4 cm rectangular support top (PCB)sla - 1.64 kB - 03/04/2019 at 23:18 |
62783.PDFThis is a 8 Channel HIGH−VOLTAGE SOURCE DRIVER that I recommend not only for the light but also to any project that needs to power more than 30mA with the ESP32 GPIOsAdobe Portable Document Format - 265.72 kB - 03/04/2019 at 16:47 |
10cm-round-lamp-v1.stlReady for the Slicer. Print without any supportssla - 494.52 kB - 02/18/2019 at 22:14 |
10cm-round-lamp-v1-support.stlReady for the Slicer. Print without any supportsapplication/sla - 74.11 kB - 02/18/2019 at 22:14 |
10cm-round-lamp-v1.blendBLENDER File. This would be the best to take if you know a bit of Blenderapplication/x-blender - 1.42 MB - 02/18/2019 at 22:11 |
rgb-lamp.blendAdding the Blender file containing small light (4.2 cm) and large light (10 cm)Im a beginner in 3D design so in case someone can make it better please tell me and add you as a collaborator in the Project application/x-blender - 1.95 MB - 02/03/2019 at 09:47 |
lamp-top.stl3D-model top of the lampsla - 1.64 kB - 02/02/2019 at 18:52 |
lamp-support.stlBasesla - 17.86 kB - 02/02/2019 at 17:03 |
rgb-lamp.stlFull lamp. Print without any supportsla - 38.46 kB - 02/02/2019 at 17:03 |
