Mini Servo Tail
A project log for Low Cost 3D printed Robot Tail
Cycloidal gearbox, brushless motors and Timing Pulleys
paul-gouldPaul Gould 06/07/2019 at 14:380 Comments
2x DS589mg (9Kg.cm 0.1sec/60deg, 40g metal gear)
1x TGY-306G  (3.7kg.cm, 0.05sec/60deg, 20g, metal gear) best servo ever
Tail Rotation (left / right)
Upper Tail Curl (Double Joint)
Lower Tail Curl (Double Joint)
