Arduino based FM radio using TEA5767 FM module, LM386 module, Audio amplifier with KA2284 audio level indicator and 0.96" SSD1306 I2C OLED LCD Display Module. The unit can also be used as a speaker(see below). Radio stations are selected via two push buttons and Audio Volume via a Potentiometer on the LM386 module.
How do you remove the lcd display recycle noise, I did reduce it by putting longer time on recycling but now the display recycle is very slow....
