Thermostat with InvIoT U1 (arduino compatible).
InvIoT U1 at kickstarter
There is a 24 hour temperature zone setting. Works for heating and A/C, with a force air or without a force air. A U1 and a 4 relay module is needed.
x-arduino - 15.78 kB - 10/16/2016 at 20:53
Setting up, connect relay, upload sketch
1. Download the library for the U1 model at InvIoT.com/download
2. Load the sketch in your arduino IDE. Go to menu file/examples/InvIoT/applications/thermostat
3. Set the pins depending on the relay module you have got.
4. Connect the wires to your heater/AC unit.
5. Upload the sketch
Setup menu:
Press the home button on U1 to set up the menu.
First setup the time and the unit that you are using (C / F).
If you like set time zones.
Used at your own risk. All the info, software and hardware is "AS-IS".
View all instructions
Parker Newman
drmed92
Alex Sokolsky
Jung Hoon Lee
Yes, delete it Cancel
You are about to report the project "Arudino compatible thermostat", please tell us the reason.
