Hack Chat Transcript, Part 2
A event log for All Things Engima Hack Chat
The unusual projects of an eccentric thinker
lutetiumLutetium 02/27/2019 at 21:100 Comments
Mike12:30 PM
Right. Did you implement the double-step initially, or only remember it later on?
Simon Jansen12:30 PM
The film simplified it a lot. It's not a 'stick in the question - get out the answer' type machine.
No, i knew about that before I started.
Building my 3D printed Enigma though really showed me physically how the double stepping works.
Simon Jansen12:32 PM
The double step thing is a classic example of a hidden defect in software. If you don't know about it and implement the code without it the code will work most of the time. But at some point you get to it and suddenly it stops working correctly.
Dan Maloney12:32 PM
The classic "How did this ever work?" dilemma
Simon Jansen12:33 PM
And with an encryption device like this once you hit that bug it's all wrong from that point on.
Kris Winer12:33 PM
How did you test you Enigma watch?
Simon Jansen12:34 PM
A lot of static code reviewing. Since it uses a lot of look up tables to model the rotors. I knew about the double stepping so I specifically tested around that. And then I used several other Enigma apps I found, on my phone and online to test against.
So I am assuming they got theirs right too!
Kris Winer12:35 PM
Might be interesting to add BLE or LoRa to the watch so as to create a sort of secure walkie-talkie!
Mike12:35 PM
I guess not many people have a real Enigma to check against.
Simon Jansen12:36 PM
The one change I made between the wristwatch and pocketwatch (apart from adding the RTC to the latter) was to improve the button debouncing.
Simon Jansen12:37 PM
Not sure I would ever use it! Some people I with have Apple watches and they tested out some walkie talkie function on that. Once.
i work with that it
Tom Nardi12:37 PM
I'd imagine there are contemporary encoded texts in an archive somewhere that you could decode as a test?
There is supposedly a real Enigma about a mile from me. Peter Jackson owns one.
Simon Jansen12:38 PM
As far as I know it's the only one in New Zealand. I have seen them in museums but never touched one. I am hoping once i finish my 3D printed version I can arrange to see the real one and compare them.
Boian Mitov12:38 PM
A friend of mine is making ESP32 based watch and it has WiFi and BLE, but no LoRa
Boian Mitov12:38 PM
doing voice over LoRa is probably not really doable as it is intended for small rare packages
Kris Winer12:38 PM
Is there anything you would propose to make the Enigma "better"? More secure, simpler, etc. Or was the idea simply to realize the historic Enigma and be done?
Simon Jansen12:39 PM
For me just historic. The issues with it are well known and were in WW2 even. The Germans and British both had better encryption devices to work around Enigmas shortcomings.
Boian Mitov12:39 PM
Dan Maloney12:39 PM
I don't know how Peter Jackson would respond, but if I had a real Enigma and someone said "Wanna see my pocket watch Engima?" I'd be all over that.
Kris Winer12:39 PM
@Boian Mitov I was thinking of short messages, not voice. you are right not enough bandwidth for voice even with BLE I think.
Boian Mitov12:40 PM
@Kris Winer Sure for message LoRa is perfect :-)
Simon Jansen12:40 PM
One think I haven't looked into too much is how quickly you could solve Enigma now. You can't brute force it, too many combination even for a massively fast computer, but apparently there are algorithms you can use.
Simon Jansen12:41 PM
I worked for Weta Workshop for a while. Peter Jackson isn't involved with that really now but I think it might help me get a foot in the door with him.
Simon Jansen12:42 PM
@Boian Mitov What batteries will it use?
I am not sure what else I could do with Enigma now. Try to make an even smaller one?
Boian Mitov12:42 PM
@Simon Jansen I have not asked him, but if you want I can put you in touch with him directly :-)
He is quite a crazy guy. Does a lot of cool projects :-)
Simon Jansen12:43 PM
Sure!
Kris Winer12:43 PM
ESP32 is not a low power device, unfortunately :<
Kris Winer12:43 PM
But electronic Enigma in a watch form factor is more practical, if that is what you are going for...
In the pocketwatch I did look at using low power mode on the Arduino and screen but in the end went with a physical switch.
Mike12:44 PM
I was wondering about the progression of size with the Enigma projects.
Mike12:44 PM
Could do a normal watch sized one perhaps?
Simon Jansen12:44 PM
I imagine there are smart watch implementations of Enigma?
Mike12:45 PM
I'm certain. But an Enigma app on an Apple Watch would be totally not interesting.
Kris Winer12:45 PM
Maybe watch version of the Bombe, just in case Enigma cyphers come back into vogue...?
Dan Maloney12:45 PM
Hals the charm is the beautiful machining, IMHO
Mike12:45 PM
Getting enough processing power in a device that size would be tricky!
Dan Maloney12:46 PM
*Half
Mike12:46 PM
@Dan Maloney , I think so. The actual build is important!
Simon Jansen12:46 PM
Most peoples eyes glaze over when you show them the watch and then mention it's an Enigma machine. Telling people it's a Bombe would probably get me arrested!
Mike12:46 PM
Ha. Try taking it through airport security...
Kris Winer12:46 PM
LoL!
Simon Jansen12:47 PM
I got the Bombe code running on a 6502 machine.
It was just quite slow.
Well, VERY slow.
Mike12:47 PM
Hmm. In that case, could be doable.
It is one of those things when you see the code and think is that all there is but really there is a lot going on.
Mike12:48 PM
What would prevent you from implementing it for the current Enigma watch?
Mike12:48 PM
Just storage?
Simon Jansen12:48 PM
The Bombe has input issues. Part of the Enigma watches was working out how to do a UI with only three buttons.
Mike12:48 PM
Hmm, yes.
Mike12:49 PM
Is that all?
Simon Jansen12:49 PM
An Arduino based Bombe would be slow too. Also the main appeal of the Bombe is that it is a big, physical machine. All the drums turning.
Kris Winer12:49 PM
Perhaps I2S mic and vice recognition would sove the input problem.
Kris Winer12:49 PM
voice
It's is why when I did the Raspberry Pi version the main focus was on the machine.
Mike12:50 PM
For the visual effect?
Simon Jansen12:50 PM
I am not sure how easy it would be to draw up a menu using voice commands!
Kris Winer12:51 PM
Just 26 letters to recognize, no?
Mike12:51 PM
I wonder if anyone runs bombe demonstrations on a regular basis. Bletchley Park, if anyone, I guess.
Simon Jansen12:51 PM
Yes, it's a nice looking device and makes appropriate whiring noises. And I also simulated the funny little half speed turn the drums do when ti finds a stop.
Simon Jansen12:52 PM
Not sure how well this will paste but:
Rotors: 2, 5, 3
Reflector: B
Test register: G
Input voltage: A
Drums: ZZK, ZZE, ZZF, ZZN, ZZM, ZZG, ZZP, ZZB, ZZJ, ZZI, ZZL, ZZO, ZZA
Connections:
U: 1i
E: 1o, 2i, 7o, 8in
G: 2o, 3i, 11o, 12i
R: 3o, 4i, 10o, 11i
A: 4o, 5i
S: 5o, 6i, 13o
V: 6o, 7i
N: 8o
H: 9i
Z: 9o, 10i
L: 12o
W: 13i
That's a Bombe menu.
BP have a working replica of the Bombe, they demo that. I tested mine by running the same menu they use for them demonstrations.
Simon Jansen12:53 PM
I also used some period documents from the time that listed example menus and the solutions.
You can think of the Drums line there as a string of Enigma machines linked together.
Simon Jansen12:54 PM
When I make something I like to make it well.
NikiSchlifke12:54 PM
So I've got one of these dimmable high power LED drivers from Meanwell. It has an external dimming port that is supposed to be used with either a potentiometer, a 0-10V PWM signal or a 10V PWM signal.
NikiSchlifke12:55 PM
So that's what I came up with..
Simon Jansen12:56 PM
I don't think they had MOSFETS when Enigma was invented :)
Jarrett12:56 PM
hmm needs a vacuum tube imo
sfrias112:56 PM
Vacuum tube was a memory registers.
Dan Maloney12:56 PM
@Simon Jansen , general question: When and how did the interest in machining come about? How long have you been at it now?
Simon Jansen12:57 PM
They had those. Look up Tommy Flowers and Colossus.
Mike12:57 PM
Colossus was fantastic. You should build a full-size replica of that!
Mike12:57 PM
Get random bits of clothing stuck in the high speed loop and ripped off.
sfrias112:57 PM
haha. Too big
Machine I think just came from doing metalwork things. It's a natural progression. From hand tools to machine tools I guess.
Simon Jansen12:58 PM
People can get to caught up in the tools though.
Mike12:58 PM
Right, I find that. Are the tools part of the project, or just a means to an end?
I am sure there is a story about how the room with Colossus was so hot from the valves the women operators in there used to remove clothing to keep cool.
Dan Maloney12:59 PM
I often find myself taking on projects simply because it means I can buy new tools.
Dan Maloney12:59 PM
I have issues.
Mike12:59 PM
I can get frustrated if I want to complete something, only to find I'm spending all my time trying to get 3D printers working or something like that.
Christoph12:59 PM
That's perfectly normal
Simon Jansen12:59 PM
Bit of both. Some tools make things easier and you get them and think how could I not have had one before. Other times the tool can be a distraction.
Christoph12:59 PM
(the tool issue)
sfrias11:00 PM
Simon Jansen1:00 PM
One problem with tools is if you jump straight to them you miss understanding the basics. Metal working is a classic example. You can do so much with just a hammer and lumps of steel.
Simon Jansen1:01 PM
My metal working mentor used to complain about carpenters who just use nail guns and have never driven a nail by hand into different timbers just to see how they feel and react.
Dan Maloney1:01 PM
Yeah, the builds with nothing but a good set of files amaze me. And Clickspring, of course.
Simon Jansen1:01 PM
Software is getting that way too. The IDEs and tools make it easy to start but people don't learn the fundamentals.
Simon Jansen1:02 PM
I like how the Arduino makes it easy to start but as soon as you start trying to do more you need to start learning more.
Simon Jansen1:03 PM
And being on actual hardware you need some understanding of that.
Christoph1:03 PM
arduino being a pretty common base also makes it easy to share stuff with others
Simon Jansen1:03 PM
And there are some amazing libraries about for it.
Simon Jansen1:04 PM
The raspberry pi I haven't got as much into. It's more a general purpose computer.
Simon Jansen1:05 PM
One of my projects a few years ago was making my own 6502 machine from scratch. Because I was always annoyed that as a kid I couldn't understand exactly how a computer actually worked. I knew it was all 1s and 0s. But how did it work with just those two things.
Simon Jansen1:05 PM
I also got to use crackle black paint on that :)
Simon Jansen1:05 PM
For me the making of things isn't usually to get the thing at the end. It's the journey getting there.
Simon Jansen1:06 PM
It's why I have lots of unfinished projects. I get what I need out of them so often stop.
Dan Maloney1:06 PM
It's after 1:00 here in the Pacific timezone, so I'm going to call an "official" end to the Hack Chat. If Simon wants to stay on and answer questions, that's perfectly fine. I do know he took the day off from work especially to share with us, and I really appreciate that. This was a great chat and I really learned a lot.
Kris Winer1:06 PM
Thanks!
Dan Maloney1:06 PM
Don't forget to tune in next week for Brian Lough talking about what it's like to go from software developer to Tindie store proprietor: https://hackaday.io/event/164058-from-software-to-tindie-hack-chat
Simon Jansen1:06 PM
I get to spend the afternoon in the garage bashing metal now!
sfrias11:06 PM
