DrumKid: aleatoric drum machine
Back to project overview
A lo-fi digital drum machine which uses randomness to create unpredictable beats. Runs on Arduino, with audio provided by the Mozzi library.
jlosada2 wrote 10/05/2019 at 22:50 point
Very cool project I have breadboarded one and it's lots of fun. Do you think it will be possible to add a clock output or input? It would be amazing to have it playing with other instruments.
Thanks for your work
Juan Pablo
Matt Bradshaw wrote 10/14/2019 at 19:23 point
Hi! Sorry I only just saw your question, but the answer is, hopefully, yes! I'm currently working on adding MIDI in/out, including MIDI clock. The code I'm using for this would also make a more simple clock in/out possible. I'm restructuring the code a bit to make this possible, so check the project in a week or two and hopefully the clock feature will exist.
whocares wrote 09/18/2019 at 17:23 point
Thank you so much Matt! This looks awesome! I can't wait to build one :D
Matt Bradshaw wrote 09/18/2019 at 17:45 point
Let me know if you do, would love to see/hear it!
