Art4Body upper part assembly trial
A project log for Building the Thor robot
Building a 6-axis robot based on the Thor robot. When size DOES matter!
olaf-baeyensOlaf Baeyens 12/12/2016 at 20:581 Comment
The upper part of the robot is Art4Body.
It consists of multiple parts that must be printed, an axis, ball bearings 2 motors, a electronic switch and a driving belt.
This is how the 3D printed version looks like. To get a sense of dimensions, it is 18 cm high.
The dome is printed separately since it needed support structures. To reduce printing time I printed the dome top separately decreasing printing time, then glued it together.
The axis is held in place by these ball bearing holders. They are not screwed in yet because I don't have all the parts yet.
An inside look to see how the parts works together. Still missing in this view are the pulleys that are driven by 2 motors and 2 belts. I still do not have these components.
The idea is that if both motors move in the same direction then the hand gets up and down. When they move in opposite direction then they rotate the hand.
During assembly I discovered that it is not easy to assemble this part. I am wondering if that part cannot be redesigned so that it is easier to put together.
Also the hand part itself is not very clear how to assemble correctly. It appears pretty lose but more on that part later on.
Olaf Baeyens wrote 12/14/2016 at 22:13 point
A colleague pointed me out asking why there is a gear box? Why there is no one motor to rotate the hand and another one to change the inclination?
I think that the Thor designer wanted to have 2 motors working so you have double the power for any direction.
