Thor hand assembly trial: Very shaky
A project log for Building the Thor robot
Building a 6-axis robot based on the Thor robot. When size DOES matter!
olaf-baeyensOlaf Baeyens 12/13/2016 at 21:350 Comments
This party is what is used to control the hand of the Thor robot but very unclear for me how to assemble it.
This is a trial assembly but it is very shaky even when assembled with the 90 degree cogs.
Inside there seems to be a ball bearing where the screw goes through it and the 90 degree cogs should push it up.
Here you can see that there is a screw just above the ball bearing of the axis.
