ESPboy multichannel sound synthesis lib
A project log for ESPboy: Games, IoT, STEM for education & fun
ESP8266, 80/160Mhz, 4/8Mb, WiFi, LCD 128х128, RGBled, HQspeaker, 8 buttons, 600mAh battery, 30x70х15mm. Under CERN license.
RomanSRomanS 04/08/2020 at 19:060 Comments
ESPboyPlaytune multichannel sound synthesis library for ESP8266 / ESPboy done
Improved port of the ArduboyPlaytune library modified to work well with the ESP8266 and ESPboy project
It supports up to 8 channels simultaneously, last channel used for tone.
WARNING: The ArduboyPlaytune library uses <sigma_delta.h> transformations so it could conflict with EEPROM and other libs. Stop play during the operations with EEPROM.
by Shiru: shiru@mail.ru
