• First GNURadio "recipes"
    Mechanical Advantage04/09/2019 at 07:47 0 comments
    This is my first collection of "recipes": GRC Cook Book.pdf. It has 11 entries titled:
    1) Turn a stream on or off from the GUI
    2) Multiplex or demultiplex signals
    3) Match dissimilar sample rates
    4) Shift the frequency of a signal without re-sampling or filtering
    5) Match the period of a digital symbol to a desired time period
    6) Stream data over a network
    7) Divide a section of bandwidth into multiple channels
    8) Call functions in a block
    9) Retrieve the baseband signal from an RF signal
    10) Convert a stream of bytes into a stream of bytes with values 0 or 1
    11) Prepare a stream of bytes for the Frequency Mod block
