Iron_Gauntlet_JLC-20191202-1359.zip
Iron Gauntlet SAO Gerbers. Unlike the Arc Badge the Iron Gauntlet actually had some changes to its design for the second and final run so you should use these. This requires 1204 Side View LEDs (1206 soldered on sideways could work) and appropriate value 0805 Resistors and of course a 2x3 Male header.
x-zip-compressed -
729.60 kB -
08/01/2020 at 04:32
Download
TwinkleTwinkie_iron_badge.X.production-V5.zip
The final production firmware for Arc Badge.
x-zip-compressed -
2.83 kB -
08/01/2020 at 04:31
Download
Arc_Badge_Parts_List_PDF.pdf
A very useful parts list that tells you where all the components go and what the component is. I personally used this during production.
Adobe Portable Document Format -
31.79 kB -
08/01/2020 at 04:28
Preview
Arc_Top_JLC-20191202-1410.zip
Arc Badge Top to be made by JLC PCB. Recommended board thickness is 0.8mm
x-zip-compressed -
738.18 kB -
08/01/2020 at 03:59
Download
Arc_Top_20190521-2023.zip
Arc Badge Top, can be made by anyone, use the JLC version if using JLCPCB. Recommended board thickness is 0.8mm.
x-zip-compressed -
795.07 kB -
08/01/2020 at 03:59
Download
Arc_Bottom_20190521-1409.zip
Arc Badge Bottom Board. Use with anyone but JLC.
x-zip-compressed -
1.95 MB -
08/01/2020 at 03:59
Download
Arc_Bottom_JLC-20191203-1501.zip
Arc Badge Bottom Board. Only necessary if you use JLCPCB.
x-zip-compressed -
1.92 MB -
08/01/2020 at 03:58
Download
Arc_Spacer_Fix.zip
This is the 3D Printed Spacer that goes between the top and bottom board. This is the 2020 Revision that fixes a potential short where the lanyard lobster claw shorts the programming headers.
x-zip-compressed -
166.67 kB -
08/01/2020 at 03:56
Download
