O2 Open Oxygen
Open Source Oxygen Concentrator for those that need a little more O2 but don't want to pay $$$.
Oxygen Concentrators have caught my attention. I like building things that make peoples' lives better. I believe this is one of them. Oxygen Concentrators are relatively simple devices. They rely mostly on Pressure Swing Absorption (PSA) in which pressurized air passes through adsorbent materials such as Zeolites, which absorbs nitrogen under pressure. This produces concentrated oxygen on the other side of the filter. The nitrogen is released by bringing the filter pressure to atmosphere. After this, the filter cycle can begin again. My plan is to make an open source design that can be made with off-the-shelf parts and without expensive/specialized tools. I will be using a CNC machine to make the top and bottom pressure plates. I am also going to attempt to analyze the oxygen and nitrogen content of the filters using IR LEDs and IR detectors. I will use this data in a feedback control loop to determine how the filter is working and when to actuate the gas control valves.
O2_Side_view.pdf
Side view of the O2 system
Adobe Portable Document Format - 489.30 kB - 05/19/2019 at 23:36
Preview
Download
O2PowerEstimate.gsheet
Starting point Power Estimate. This is for worst case power draw of the system.
gsheet - 0 bytes - 05/15/2019 at 02:03
Download
rodnrob wrote 03/25/2020 at 06:42 point
Are you aiming this device at the urgent need for Covid19 sufferers?
Do you have some Specs on what you need to acheive? eg. Output volume, pressure, flow?
From this we need to figure out what size pump/compressor we need.
For guidance see this open source project: https://reprapltd.com/open-source-oxygen-concentrator/
manta103g wrote 02/11/2020 at 23:58 point
join my
Powerful Oxygen Concentrator 1,000litres / min.
Powerful Oxygen Concentrator 1,000litres / min. for use in trucks
project
https://hackaday.io/project/169911-powerful-oxygen-concentrator-1000litres-min
manta103g wrote 02/10/2020 at 15:19 point
"You do not have appropriate privileges for this action.
stays for what ?
why do you  collect and process personal data ?
manta103g wrote 02/10/2020 at 15:03 point
Hi, great project
interested in DIY oxygen concentrator
Today I go to buy Zeolites
How to build molecular sieve ?
