Make a Mecanum wheel by yourself!!!
A Mecanum wheel created for everyone!
This Mecanum wheel is being created for everyone who want to make a Omnidirectional mobile platform by themselves.
You don't have to buy any expensive parts, you just need to buy a tittle cheap parts and the other parts can be print by your 3d printer.
Matters needing attention:
As we all know, Mecanum Wheel has the opposite one and the positive one. A Omnidirectional mobile platform can consists of four Mecanum Wheel(two opposite wheel and two positive wheel )
So you can find two STL files one of them called "p0" and the other one called "p0-m".
To build a opposite wheel, you should print two "p0", one "p1" and nine "p2".
To build a positive wheel, you should print two "p0-m", one "p1" and nine "p2".
p0.STL
Standard Tesselated Geometry - 5.95 MB - 05/08/2019 at 16:43
Download
p0-m.STL
Download
p2.STL
Standard Tesselated Geometry - 4.67 MB - 05/08/2019 at 16:43
Download
p1.STL
Standard Tesselated Geometry - 2.78 MB - 05/08/2019 at 16:42
Download
  • 1 × 3d printer To print some necessary parts
  • 9 × M3 non-self-locking nut
  • 9 × M3 Half-tooth hexagonal screw
  • 1 × Silica gel thermal shrinkage tube with length of 1 meter and diameter of 16mm
  • Print the parts
    Tony-Lin05/08/2019 at 17:33 0 comments
    All parts of a wheel are shown in the figure below.
    If you are going build a mobile platform, you should print four Mecanum Wheels. It cost me about five days to print 36 "p2", 4 "p0", 4 "p0-m", 4 "p1".
    Right, that's a long time!
View project log
  • 1
    Printing all the parts
    Download all the STL files, then import them to your slicing software.By the way, the slicing software I used is Cura 15.04.
    Transform the STL files into Gcode files, then you can use them to print all the parts.
    As what I had said in the log, that will cost you a lot of time. So, enjoy it!
  • 2
    Prepare other necessary parts
    You still need some necessary parts except the 3d printing parts. Please refer to Components.
    The other necessary parts you need to assemble a Mecanum Wheel are shown in the figure below.
  • 3
    Fix one of the end of the iron shaft with 502 glue first
    This step is a great test of skill.
    As shown below, you should fix the iron axis one by one. Take it easy!
View all 5 instructions
