the airdrum license.pdfOur license.Adobe Portable Document Format - 14.55 kB - 08/06/2019 at 18:27 |
IR_TX_ledPositioningBlock.stlThis part is to keep the Tx IR LED's in place to make soldering easierStandard Tesselated Geometry - 142.66 kB - 08/04/2019 at 23:55 |
Airdrum_base_module.stlThe base moduleStandard Tesselated Geometry - 237.39 kB - 08/04/2019 at 23:55 |
Speaker_module_top_solo.stlA single speaker topStandard Tesselated Geometry - 43.25 kB - 08/04/2019 at 23:55 |
IO_panel.stlPanel for the base module for power switch, charging port and battery indicatorStandard Tesselated Geometry - 65.90 kB - 08/04/2019 at 23:55 |
Speaker_module_top_duo.stlA dual speaker topStandard Tesselated Geometry - 77.23 kB - 08/04/2019 at 23:55 |
Clear_top_panel.stlPrinted in clear plastic to diffuse the LED lightStandard Tesselated Geometry - 34.85 kB - 08/04/2019 at 23:55 |
Speaker_module_bottom.stlBase module for a speaker panelStandard Tesselated Geometry - 70.79 kB - 08/04/2019 at 23:55 |
The_Airdrum_hackaday.zipEagle files and BOM for one panelx-zip-compressed - 1.02 MB - 07/25/2019 at 01:01 |
