Current proress
All files associated with this project can be found using the GitHub link or clicking here.
This currently includes a schematic, PCB layout, and datasheets for components used in the design. More information will be added during this project.
Capacitive Flex Sensors
The flex sensors have been designed as finely spaced metal contacts on the flexible substrate.
On the right hand side of the PCB design, there are two sensors that can be cut off the main and attached to flexing parts (e.g. fingers) .
When the sensor is bent, the metal contacts get closer together (pr further apart depending on bend direction) and the capacitance will change.
The micro-controller chosen for this PCB has built in peripherals for measuring changes in capacitance. These are usually used for touch sensing.
elowe5
