The idea is to try to replace the wiring of my friend's project ( http://www.ffviman.fr/switch-snes/presentation-historique-switchless.html )
(only available in french for the moment ... soonish in english, google translate over here : https://translate.google.com/translate?hl=fr&sl=auto&tl=en&u=http%3A%2F%2Fwww.ffviman.fr%2Fswitch-snes%2Fpresentation-historique-switchless.html )
As you can see on the pictures you'll find a lot of wires. I think this could be replaced by some band ca. 6-8 mm wide and about 15-20 cm long.
The whole thing would basically look like a flat ribbon cable with some bends on the most outter traces to bring them to the needed solder joints. (2nd picture)
As you can see, there already is a "receiver" pcb with a flex connector on it (3rd and 4th pictures). (Made by OSHPark)
Due to life/other projects/budget this did not progress any further since october 2017.
This would be some sort of surprise / gift to him :)
ours1011
