Abandoned and Restarted
A project log for Prototype SCARA Mark II
My second SCARA project. This time it will be twice as big and geared.
agpcooperagp.cooper 06/24/2020 at 09:360 Comments
Why I Stopped
I stopped because I was waiting for 1.2mm diameter end mills for the gear wheel. As they take about six weeks from China fro delivery I went on to other things.
I had moved on by the time the 1.2mm end mills arrived!
I did have a look a the project a month or so ago, made some edits to the design, nothing exciting. The problem remained, the project was complicated and expensive.
So I put it on hold.
Another Approach
While cruising the Internet, I came across the Maslow CNC project:
Okay, it deserves a "WOW". Getting this technology to cut a 4ft x 8ft sheet of plywood is an achievement.
Parallel or 5 Bar SCARA
Okay, if they can get he Maslow CNC project working, I can get a parallel or 5 bar SCARA working (i.e. able to cut plywood). Here is an example of a % bar SCARA (http://fab.academany.org/2018/labs/fablabbottrop/group_week14_15.html):
Why a 5 Bar SCARA?
The main advantages of the 5 bar SCARA are:
The main downside is:
Possible solutions to the application of force:
Other problems:
Here is a first drawing:
And a close up of the motor gearing and hinges:
Note: The gears are attached to the "near" arms.
SCARA Mathematics
Next is the Mathematics.
Alan Cooper
