First Batch of Boards
A project log for PCB Decahedron
You can get 10 pcbs from most manufactures for cheap if they are under 100mm on each side. Let's make some shapes.
ian-shannon-weberIan Shannon Weber 08/06/2019 at 00:450 Comments
I got a hold of 60 pcbs from PCBway, 30 with plated edges and 30 with castellated holes. I did a quick test of one of the panels and it worked. I am working on a 3D printed jig to help be assemble the final shape. I am using Sn60Pb40 solder for the components and I plan to use SAC solder as the "welds" between the boards.
