Failure to Launch
A project log for PCB Decahedron
You can get 10 pcbs from most manufactures for cheap if they are under 100mm on each side. Let's make some shapes.
ian-shannon-weberIan Shannon Weber 08/08/2019 at 23:560 Comments
I was unable to correctly do the 3D geometry when designing the PCB. Attempts to solder and assemble the sculpture lead to over heating the castellated edges. The de-laminated pads lead to throwing away the design. It was a critical failure in the project.
Failed Soldering
