smd tape holder
A holder for 8mm cut tapes for a pick and place machine
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 0
  • Instructions 0
  • Discussion 0
This is a quick change holder for smd cut tapes. It can be used for manual or automatic pick and place operations. Ten 8mm tapes can be inserted. Tolerances are tight, so the tapes stick by themselves, but are easy to install and remove. 1.5mm holes can be used for visual alignment or with additional alignment pins. This was cut from birch wood on a cnc, but 3d printing should also be possible. smallest feature is a 0.5mm ledge. File was created using Fusion360, should be trivial to adjust dimensions and number of tapes.
