Executing ArduBlock can be done using the following commands:
This is where I made changes to the files to create the Button.
All files can be found under /Users/cecilia/Downloads/BarnabasRoboticsArdublock/ardublock-all/src/main/resources/com/ardublock/block...
Changes to the ardublock.xml file:
Changes to the ardublock.properties file:
Changes to the block-mapping.properties file:
Finished product:
