JTAG to SWD Adapter
Generic JTAG to SWD adapter for fast and reliable debugging with SWD interface. No need for complicated wiring.
0 followers
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 0
  • Instructions 0
  • Discussion 0
Legacy Arm 20-pin JTAG/SWD IDC connector to SWD with simple header. Useable with all JTAG header programmer like ST-Link, J-Link etc. You can also use this board with directly programmer or JTAG cable.
This product designed for developers to simplify development and debugging process.
Pin Number Description
1 T_VCC
2 T_SWCLK
3 GND
4 T_SWDIO
5 T_NRST
6 T_SWO*
7 P_VCC**
*Optional, required only for Serial Wire Viewer (SWV) trace.
**Output of programmer VCC. Not need for programming. This pin will be use in the future isolator project!
