Model 74181: P Outputs
A project log for Homebrew Machine 2
An 8 bit breadboard computer based on the Malvino SAP-2.
Brandon ReinhartBrandon Reinhart 07/21/2019 at 05:522 Comments
Two days ago I completed the propagator P output for the model 74181. It looked like a complete mess.
The circuit was functional, but didn't really serve the purpose of making that functionality transparent. I mean, there's a laundry list of bad things going on here.
This didn't meet my standard. I ripped everything out and reworked the circuit.
Here is the current state of the model:
The input switches are more clearly separated. These DIPS do not want to stay in the breadboard, though, so I ordered a different kind to see if I can get better results.
The organization of the logic is as follows:
I'm pretty happy with the progress so far and I've now hooked up this logic enough times that I understand it well.
The next task will be to wire up the generate bits!
Dave's Dev Lab wrote 07/21/2019 at 19:59 point
fantastic looking build!
Brandon Reinhart wrote 07/21/2019 at 23:41 point
Thanks!
