Scarab
A light show of a beetle circuit board
Public Chat
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 0
  • Instructions 0
  • Discussion 0
Scarab is a beetle-shaped circuit board with 18 multiplexed LEDs (3x8) controlled by a Microchip ATtiny1614. The square pad on the top — with the 'B' on it — is a capacitve-touch 'button' used to interact with the Scarab and change between the various light shows.
The top side of the PCB has two layers of soldermask: first green and then red. Then, en ENIG finish. It was expertly produced by Eurocircuits as part of a exploratory collaboration.
I designed the Scarab using my open source PCB design software called PCBmodE.
I'm currently developing the software for the MCU.
