close-circle
Curve Tracer V2
A project log for Microcontroller based curve tracer
Electronic Curve tracer for measure and compare components on circuit boards
Máté TóthMáté Tóth 11/28/2016 at 12:291 Comment
I am about to start build the updated version of my curve tracer. I was thinking about a lot, what will I need to improve the functions on the tracer. I was looking the Huntron 3200S spec on the internet, when I specified the functions on mine tracer.
I was sure, if i would like to updrade, I will need more space and a bigger screen, because the last one was a bit small (2.3" LCD). I found a 3.95" LCD touch screen with better resolution (480x320).
The new version will have:
  1. Two channel input with alternating function, and with that I will able to compare two component at the "same" time.
  2. Multiple frequency, voltage (sine wave) and input resistance ranges.
  3. Some buttons with inbuilt LED and a touch display for the easier operation.
  4. End of the project I would like to make a software for PC and with that I will can log characteristics for save that later repairs.
  5. If I will have enough money, I would like to make a scanner, wich has around 64 input to measure characteristics on IC-s directly with much better speed.
Only one main part missing, which is an Arduino DUE.
Some photos about parts, what I bought:
PROFESOR wrote 01/22/2017 at 10:19 point
Hi, Mathe Please add  schematic diagram and arduino ino file. Best regards.
