• Installing Mobilenet using Arduino
    Brenda Armour17 hours ago 0 comments
    Software can be uploaded to the Maix Go using Arduino ! I had a version already loaded but it did not work. I downloaded the Windows Store version using this link .
    I found steps to add the Maix Boards to the IDE. The steps are well written and easy to follow. The steps can be found here.
    The next step is to set up mobile net on a SD card.
    Download model here: * http://dl.sipeed.com/MAIX/MaixPy/model/mobilenet_0x300000.kfpkg * Unpack it(zip format), get m.kmodel, change name to a short name "m" for example, * put it in SD card at root path
    Place  the SD card and reboot.
  • Assemby of SiPeed Maix Go Kit
    The best instructions is a video made by Sipeed:
    Of course I paused quite a lot to follow the steps.  I did not install the WiFi antenna . There was a nice screw driver provided for those tiny screws.
  • Steps to Build Wild Trap
    Brenda Armour18 hours ago 0 comments
    I will build a separate log for:
    1.  Assembly of Maix Go Kit
    2. Programming Arduino with Maix Boards and compiling MobileNet for Image Processing
    3. Storage of Data Collected on SD Card
    4. Taking it Outside
    There will also be a log on setting up the Gertbot on Raspberry Pi 3
