Material picking
06/29/2014 at 19:06 • 0 commentsOrdered a sample of the mirrored acrylic to see if the TFT will be bright enough to push light through it from the back. Might look super sexy if it works
Planning
06/29/2014 at 18:52 • 0 commentsPlan right now is to get the entire pi and screen combo to be under 7mm so I can get a wood frame laser cut from ponoko and then a piece of leather cut to put on top of it
