256 Colors
A project log for PicoPew
A PewPew shield for the TinyPICO
Christian WaltherChristian Walther 11/18/2019 at 21:332 Comments
So far, my pew Library has only displayed the same four black/red/green/orange colors as existing PewPew devices with red/green displays. The IS31FL3733 LED driver however supports 256 shades of brightness per color component. Let’s take advantage of that!
There is no precedent for how to handle this in the pew API, because so far no PewPews except for some of Radomir’s internal prototypes have supported more than 4 colors. The opportunity is mine to come up with a way that can hopefully be standardized in the future.
The existing pew.Pix drawing surface class supports 256 colors. With only two color components and 64 pixels, that ought to be enough for anybody. No need to extend anything there until we get to the RGB PewPew.
But how to choose the palette mapping the 256 possible values to a sensible subset of the 65536 possible colors? Some desirable properties are the following:
The second and third property contradict each other: The second requires that the most significant bit of each component is placed in bit 0 and 1, respectively, while the third requires placing them with their group. They cannot both be satisfied by the same set of colors. However, there is enough space in the 256 colors to have two sets that satisfy one each. So at least a program gets the choice of whether to degrade gracefully to 4-color devices or to use true-color mode.
Here is a palette I have come up with according to these considerations. (The colors don’t look that crummy on the real device, but I had some trouble converting the values from the yellowish green, super-bright red, and vastly different gamma of the LED matrix to something suitable for computer monitors.)
Examined in terms of the bits of the color value, it works like this:
76543210
00darknessuser dataredgreenred/green compatible
01hueuser databrightnesssingle-color compatible
1redgreentrue-color
Besides this default palette, programs should be able to set an arbitrary palette of their own. In addition, rather than setting a completely new palette, they should be able to cyclically shift the palette by a specified offset. This is useful for certain sorts of color animations, and by selecting specific offsets in the default palette it also allows the user to choose the color scheme to use for four-color programs.
This is now implemented in the library as a new API function pew.palette(), and as the next step I intend to write some demos using it to put it to the test.
de∫hipu wrote 11/19/2019 at 06:28 point
I wonder if the repeated colors in the first palette really have to be identical. If they differed very slightly, it would still be impossible to tell them apart, but they would be useful for gradients.
Usually palettes tend to assign the extra bit to green, because our eyes are more sensitive in that spectrum and can discriminate more shades.
Christian Walther wrote 11/19/2019 at 10:04 point
You may be right about the identical colors, I’ll do some experiments.
I’m aware of the extra bit for green, but that is for RGB displays, where the relative intensities of the primaries are tuned such that they make white together. This is not the case on the LED matrices I have, where the red is a lot brighter than the green. Together, they make reddish orange, not yellow. For a somewhat perceptually even red-yellow-green gradient, I need to use only part of the red range. That’s why the extra bit for red is useful.
