h - 6.02 kB - 09/08/2019 at 14:52 |
ZZZ_doubleResolution.hthis is code that can double resolution. you will want to change area that gets numbers from main memory. the output of a higher resolution cell isfloat temp=DoubleResolutionValue(x, y) and result is stored in temp. it is cached and manages hit and miss as well h - 4.19 kB - 09/03/2019 at 23:20 |
