Changed CPU from 6 to 10 MHz
A project log for 3-Chip Z80 Design
Combining a Z80 retro design with a modern PSoC CPU.
land-boardscomland-boards.com 11/02/2019 at 10:330 Comments
Replaced the 6 MHz Z80 with a 10 MHz Z80 part. This change is very simple in PSOC Creator. Just set the CPUCLK to 10 Mhz.
It works.
Tried overclocking at 12 MHz and it worked. Booted CP/M. Ran MBASIC.
Also tried 15 MHz and it also worked.
