Clock Resources
A project log for Not Quite Useless Raspberry Pi Replacement
Make a Raspberry Pi replacement using a Cypress Semiconductor Programmable System on a Chip (PSOC 5)
land-boardscomland-boards.com 10/07/2019 at 22:280 Comments
I only tweeked the clock resources a bit from the default values.
This sets the USB to the accurate 48 MHz. The PSoC CPU is running at 64 MHz. It all runs off the IMO which is accurate to 0.25%.
So, it looks like the FPGA as all GPIOs is an easy fit into the FPGA.
Time to order boards.
