➢Step descriptions:
✦Step 1:Materials we need:
Arduino UNO,
Breadboard,
Jumper wires,
LEDs
Programming cable,
220ohm resistors,
Sound sensor,
✦Step 2:On a breadboard, connect LEDs+ve leg with 220ohm resistor.
✦Step 3:Small leg of led is -ve, with the help of jumper wire connect it with GND of arduino.
✦Step 4:Connect a jumper wire to the +ve end of resistor and then connect it with arduino pin9.
✦Step 5:Connection:
arduino sound sensor
pin no2. out
vcc vcc
gnd gnd
✦Step 6:Coding as in the pic.
✦Step 7:Test
Video on Youtube:
