Retrofitting of a vintage Millet backpack
Found an old backpack from french brand Millet and retrofitted with lights and sensors
My first wearable! This project deals with a vintage backpack, model "le Sherpa" from Millet, and built for the famous alpinist Walter Bonatti, approx from 1960 (I think), modified with an Arduino to add and control rear leds for my bike trips. I'm going also to add an accelerometer/gyroscope to detect my back movements and control turning lights.
First step of the retrofitting
I've placed everything in the small rear pocket on the backpack.
Leds are connected to an Arduino Nano sewed inside of the pocket. Also the power is a small smartphone battery pack placed inside of the pocket.
The switch is made with the zipper, by closing the zipper the Arduino become connected and turns on. Opening the backpack zipper turn off the device.
Everything is connected using conductive threads, which was quite difficult for me... but it was also funny.
Here is a small video with lights and zipper switch:
The leds are powered using POV techniques to reduce the power consumption through Arduino pins.
Next step, turning led signs
I will add an accelerometer/gyroscope (I've got some GY-521 here) to detect the inclination of my backspine (left or right) to determine the left or right led sign before turning when I'm on bike.
  • Preparing for accelerometer
    Giulio Pons02/29/2020 at 17:20 0 comments
    I will connect the Arduino Nano this way:
    I will use GY-521 accelerometer.
    I've placed the GY-521 here:
    I'm also waiting lilypad yellow leds and conductive thread. I've prepared the Arduino Nano to connect GND, VCC, A4 and A5 to accelerometer.
View project log
