Adobe Portable Document Format - 23.36 kB - 01/09/2021 at 11:02 |
Adobe Portable Document Format - 34.47 kB - 01/09/2021 at 11:02 |
Adobe Portable Document Format - 33.91 kB - 01/09/2021 at 11:02 |
Adobe Portable Document Format - 35.24 kB - 01/09/2021 at 11:02 |
JPEG Image - 1.40 MB - 11/23/2020 at 16:36 |
Adobe Portable Document Format - 27.16 kB - 11/23/2020 at 16:36 |
Adobe Portable Document Format - 32.09 kB - 11/23/2020 at 16:36 |
CharGen-1.BINCharacter Genarator code for 80 Col VDUoctet-stream - 2.00 kB - 12/11/2020 at 16:45 |
JPEG Image - 732.02 kB - 11/19/2020 at 16:00 |
JPEG Image - 800.41 kB - 11/19/2020 at 16:00 |
Adobe Portable Document Format - 34.96 kB - 11/19/2020 at 16:00 |
ms-excel - 1.04 kB - 11/24/2020 at 08:55 |
application/pdf - 306.45 kB - 11/19/2020 at 15:59 |
JPEG Image - 1.58 MB - 11/19/2020 at 15:58 |
JPEG Image - 1.06 MB - 11/19/2020 at 15:58 |
Adobe Portable Document Format - 50.63 kB - 11/19/2020 at 15:58 |
KBD2 SourceCode V2.2.zipPIC code for USB Keyboard v 2.2x-zip-compressed - 642.04 kB - 01/10/2021 at 09:11 |
Adobe Portable Document Format - 34.79 kB - 11/20/2020 at 08:32 |
ms-excel - 2.05 kB - 11/19/2020 at 15:58 |
Adobe Portable Document Format - 35.30 kB - 11/19/2020 at 15:58 |
CPU-Compact flash issue 4 assembled.jpgPicture of Assembled PCBJPEG Image - 1.39 MB - 10/14/2020 at 09:39 |
CPU-Compact Flash Issue 4 bare PCB.jpgPicture of bare PCBJPEG Image - 1.36 MB - 10/14/2020 at 09:39 |
CPU-CF Issue 4.PDFSchamatic of sameAdobe Portable Document Format - 49.96 kB - 10/14/2020 at 09:39 |
Adobe Portable Document Format - 35.64 kB - 10/25/2020 at 09:42 |
ms-excel - 1.73 kB - 10/25/2020 at 09:42 |
IO Port module Issue 2 bare PCB.jpgPicture of bare PCBJPEG Image - 725.90 kB - 10/14/2020 at 09:37 |
Bill Of Materials IO Port Module Issue 2.pdfList of components neededAdobe Portable Document Format - 30.48 kB - 10/14/2020 at 09:37 |
IO Port Module Issue 2.PDFSchematic of sameAdobe Portable Document Format - 28.12 kB - 10/14/2020 at 09:37 |
Adobe Portable Document Format - 40.16 kB - 10/18/2020 at 10:19 |
Adobe Portable Document Format - 34.71 kB - 10/18/2020 at 10:19 |
x-zip-compressed - 889.60 kB - 10/18/2020 at 10:19 |
Adobe Portable Document Format - 49.91 kB - 10/07/2020 at 15:34 |
RS232 Card Issue 2 3D image.png3D image of CardPortable Network Graphics (PNG) - 355.46 kB - 10/07/2020 at 15:34 |
Adobe Portable Document Format - 35.62 kB - 10/07/2020 at 15:34 |
PSG Issue 2 built.jpgProgrammable Sound, Text to Speech and an RTC (Real Time Clock).JPEG Image - 1.38 MB - 10/04/2020 at 15:30 |
PSG1 Issue 2.PDFSchematic...application/pdf - 49.80 kB - 10/04/2020 at 15:30 |
Bill Of Materials PSG1 Issue 2.pdfWhat you need.application/pdf - 36.39 kB - 10/04/2020 at 15:30 |
CFBOOT22.BINZ80 Code for Boot Epromoctet-stream - 1.25 kB - 10/02/2020 at 18:05 |
JPEG Image - 1.61 MB - 09/29/2020 at 08:26 |
Adobe Portable Document Format - 30.67 kB - 09/29/2020 at 08:26 |
Adobe Portable Document Format - 33.82 kB - 09/29/2020 at 08:26 |
JPEG Image - 1.66 MB - 09/29/2020 at 08:26 |
Adobe Portable Document Format - 28.21 kB - 09/29/2020 at 08:26 |
Adobe Portable Document Format - 30.48 kB - 09/29/2020 at 08:26 |
plain - 1.27 kB - 09/29/2020 at 08:26 |
AP-VDU80-3.PDFThe schematic for the 80 Col VDU card.Adobe Portable Document Format - 52.92 kB - 08/20/2020 at 15:26 |
VDU80 3D board TOP Issue 3.jpgA 3D view of the 80 Col VDU card.JPEG Image - 295.00 kB - 08/20/2020 at 15:26 |
Bill Of Materials AP-VDU80-3.pdfWhat you need.Adobe Portable Document Format - 45.41 kB - 10/21/2020 at 15:11 |
InterakSystemNotes.pdfAll of the cards are now available on eBay ;Just search under Interak. All use common Z80 and TTL chips 74LS or 74 HTC. All files needed are above, application/pdf - 8.44 MB - 10/22/2019 at 09:55 |
