Hackaday.io Hackaday.io
Sign up Log in
GameWing
This hack is a wing board for the Adafruit Huzzah32 providing game controller connectors, analog audio and video
bitlunibitluni
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
2k views
1 comments
15 followers
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 2
    • View all
  • Instructions 0
  • Discussion 1
View Gallery
2k
1
15
17
Team (1)
  • bitlunibitluni
Join this project's team
  • Code
  • Details on Color PAL
  • Code version 2
ongoing project
ESP32
Related lists
Video Games
Both retro and novelty. Games, consoles, controllers, gadgets.
This project is submitted for
  • Take Flight with Feather
This project was created on 11/01/2019 and last updated 6 years ago.
Description
This simple shield provides two SNES connectors an SD card slot and RCA connectors for analog audio/video. The implementation of the Color PAL signal is completely done in software utilizing the second core to process the modulated data from the YUV frame buffer. This shield will only work with HUZZAH32 boards since the performance and the SRAM is needed. The second version supports USB Controllers. This simplifies the sourcing of the parts. Check out the Log for detailed infos.
Project Logs
Collapse
  • USB Controllers
    bitluni • 12/31/2019 at 18:32 • 0 comments
  • v1.1 Shield Build
    bitluni • 11/11/2019 at 18:56 • 0 comments
View all 2 project logs
Log In/Sign up to comment
Sign up with Github
Sign up with X
OR
Alex Orear wrote 01/07/2020 at 22:38 • point
I am going to make this with a breadboard, do you know what would be a compatible sd card breakout to use with this project? Does the color output work on NTSC or PAL only?
Emulate Honda Odyssey 2007 RES DVD player to enable audio/video streaming to RES screen
Project Owner Contributor
Hacking Honda Odyssey 2007 RES DVD-player
dccharacterdccharacter
My friend salvo expanded his Oberheim - Viscount MC2000 with a DreamBlaster X2 to get built in sound
Salvo's Oberheim - Viscount MC2000 sound expansion
serdefserdef
A multi-track, multi-layer Audio Looper for use in a iive Guitar performance setting running on an rPi in bare metal with a 3D printed case.
rPi Bare Metal Audio Looper
patrickPatrick
BBbox field recorder needed a networking option and AVB USB was expensive.
USB <-> AVB 32x32 channel interface
ben-bilesben biles
Going up?
© 2026 Hackaday
Yes, delete it Cancel
You are about to report the project "GameWing", please tell us the reason.
Send message
Remove Member
