Hackaday Supercon 2019 Badge Enclosure.f3z
Fusion model of the complete badge enclosure.
f3z -
20.84 MB -
11/12/2023 at 23:34
Download
Supercon2019 - Main Body Top.stl
Top shell of the badge enclosure.
Standard Tesselated Geometry -
4.33 MB -
11/12/2023 at 23:33
Download
Supercon 2019 - D-Pad.stl
Control D-Pad
2.06 MB -
11/12/2023 at 23:33
Download
Supercon 2019 - Cartridge Body.stl
Covers the "cartridge port". Can also be the body of a cartridge PCB. Probably not designed to fit whatever hacking PCB they gave us.
759.46 kB -
11/12/2023 at 23:33
Download
Supercon 2019 - Circle Button.stl
Front Button with a circle on it.
654.77 kB -
11/12/2023 at 23:33
Download
Supercon 2019 - Main Body Bottom.stl
Bottom of the main body. Humps are to accommodate the battery holders, which were larger than expected.
4.21 MB -
11/12/2023 at 23:33
Download
Supercon 2019 - Lightpipe Top.stl
Lightpipes for top LEDs... please place these further apart next time!
931.82 kB -
11/12/2023 at 23:33
Download
Supercon 2019 - IR LightPipe.stl
Lightpipe for IR LED... hopefully this doesn't make it work worse.
594.81 kB -
11/12/2023 at 23:33
Download
Supercon 2019 - Triangle Button.stl
Front button with a Triangle on it
634.75 kB -
11/12/2023 at 23:33
Download
Supercon 2019 - Lightpipe Side.stl
Lightpipe for the LEDs by the buttons that would be covered by your hand in normal operation. Please make these further apart next time!
823.13 kB -
11/12/2023 at 23:33
Download
Supercon 2019 - X Button.stl
Front button with an X on it.
613.07 kB -
11/12/2023 at 23:33
Download
Supercon 2019 - Square Button.stl
Front Button with a Square on it
637.97 kB -
11/12/2023 at 23:33
Download
Supercon 2019 - Switch.stl
Power Switch
336.80 kB -
11/12/2023 at 23:33
Download
