POE Support added
05/31/2020 at 21:13 • 0 commentsI finally got around to testing for POE support. It works fine. Only these two parts were needed to replace the wall wart/USB-C power supply:
Uctronics PoE Splitter Gigabit 5V, IEEE 802.3AF,
zdyCGTime 0.5FT USB 2.0 Micro Female to USB Type C Male
Components List and Suppliers
01/05/2020 at 21:25 • 0 commentsRaspberry Pi 4 Model B - 2GB RAM $45.00
Official Raspberry Pi 4 Power Supply $8.00
Heat Sinks for Raspberry Pi 3 model B $3.99
Heatsink for Raspberry Pi Zero $1.99
Uputronics Raspberry Pi GPS expansion Board $39.95
485-3527 Adafruit PiOLED monochrome OLED for RPi $14.95
485-2223 Adafruit GPIO Stacking header for Pi Extra-long 2x20 pins $2.50
Waterproof GPS Active Antenna, 28dB gain, 3-5VDC, SMA $14.99
Electrronics-Salon M2.5 nylon hex M-F spacer/screw/nut kit for RPi $12.99
Raspberry Pi 4b Fan, iUniker 30x30x7mm $7.99
POE stuff (future)
Uctronics PoE Splitter Gigabit 5V, IEEE 802.3AF $14.96
zdyCGTime USB-C to Micro USB Adapter $7.99
zdyCGTime USB 2.0 micro female to USB Type C male right angle $7.55
misc parts (Frys, spares)
1K resistor
1N4001 diode
NPN transistor (300mA, 2N2222A)
Small sheet of plexiglas/polycarbonate left from other projects for top/bottom
A short piece of vinyl corner bead (used with sheetrock) to mount fan
