I added a feed screw onto my lathe so I don't wear out the threading screw doing repetitious feed or boring work, and because driving through the carriage traverse handle always leaves irregularities in the surfacing. This software uses a timer interrupt to precisely sequence stepper motor pulses, and uses multiples of the timer interrupt period to determine stepper speed. Right now it's set up to drive a half-step L298, but can be easily changed to a step/direction driver for a Trinamic or A4988. It could use a 2x16 LCD. I happen to be using a 4x20. Picture shows the same software/hardware driving a mill fourth axis rather than the lathe longitudinal axis.
arduino sketch: uses timer2 overflow interrupts to evenly sequence half-step signaling to drive a stepper motor with a dual H-bridge. It displays speed, direction, and on/off status to an LCD, and needs two buttons (on/off, left/right) set up with pullups to +5V to operate. Stepper is attached to lower 4 bits of PortB, lcd to portD, and the buttons to upper bits of PortB.
Software can enhance the overall customer experience. From customer relationship management systems to online support portals, software enables businesses to better understand and serve their customers, resulting in improved satisfaction and loyalty https://softtechbr.com/.
