clock_disk v2.stl
Top plate for clock assembly, contains notches and holes for holding the paper clip spacers and a hole in the center for mounting the LED bar.
Standard Tesselated Geometry - 117.86 kB - 01/24/2020 at 01:09
Download
clock_bottom v2.stl
Bottom disk that holds the clock mechanism a has holes and notches for holding the paper clip spacers.
Standard Tesselated Geometry - 113.56 kB - 01/24/2020 at 01:09
Download
