HID_Touch_A031219.zipUSB HID (Keyboard) example with bootloader activation when the TIN2 touch key is activated (SDCC source code).x-zip-compressed - 10.45 kB - 02/01/2020 at 10:24 |
touchkey_A031219.zipTouch Key example with bootloader activation when the USR key is pressed (SDCC source code).x-zip-compressed - 3.52 kB - 01/31/2020 at 13:29 |
blink_prog_A031219.zipBlink example with bootloader activation when the USR key is pressed until blink stops (SDCC source code).x-zip-compressed - 2.21 kB - 01/29/2020 at 21:12 |
blink_A031219.zipBlink example (SDCC source code).x-zip-compressed - 1.83 kB - 01/29/2020 at 21:11 |
CH552 Datasheet_C111367.zh-CN.en.pdfCH552 Datasheet English-ish. Not a great translation, only to see the differences with CH554. Better use the CH554 Datasheet to start.Adobe Portable Document Format - 1.47 MB - 01/30/2020 at 08:24 |
A031219 - SCH.pdfSchematicAdobe Portable Document Format - 88.41 kB - 01/31/2020 at 15:04 |
A031219 - PCB Layout Guide.zipPCB Assembling Guidex-zip-compressed - 380.15 kB - 01/28/2020 at 16:38 |
A031219 - Gerber.zipGerber files for PCB productionx-zip-compressed - 145.79 kB - 01/28/2020 at 16:39 |
A031219_2x_Pannel_V-Cut_Gerber.zipGerber files with 2x panellization for V-Cut (added 1mm of space between the two boards for the cut)x-zip-compressed - 267.67 kB - 01/30/2020 at 10:59 |
A031219 - BOM.odsBOM filespreadsheet - 20.85 kB - 01/28/2020 at 16:38 |
