First slice
A project log for Bipolar Discrete UART
Because making discrete clocks is not an end in itself.
Yann Guidon / YGDESYann Guidon / YGDES 02/20/2020 at 23:080 Comments
So one latch "building block" is this :
BOM:
A "slice" is a "DFF and a half" : one master latch and two slaves, one of them can be connected to the processor.
Source here.
This is pretty easy to place & route on a small board.
In this example, the "slice" is configured for the receive circuit (SIPO). The 3 latches must be connected differently to perform the PISO function, so each "slice board" would have each individual latch connected to the outside so a backplane can configure the correct function.
