Almost there
A project log for Breadboarded 3-Axis Sine-Cosine Controller
Build this controller to engrave the PCB for your permanent controller
darrin-bDarrin B 02/28/2020 at 01:450 Comments
Now this becomes a coding project. Converting G-Code to a stream of symbols, seems simple enough. There's also keeping phases synchronized for smooth stepping, and adjusting the output for direction changes. Much to be done, I'll be back.
