Wipkat Slippy 3D Printer
A 3030 frame prototype printer with some innovative mechanics
The printer will be built with a minimum of printed parts, mostly out of aluminium frames and scrap parts i have laying around. The printer features what I like to call a “floating bed”. The bed is designed with 2 inverted guide rails that run in unison, each powered by 2 nema 17 motors. The way it is constructed allows the rails to “float” over a panel, with the belts hidden underneath.
  • 2 × MGN12 Rail 60cm https://www.123-3d.nl/123-3D-MGN12H-lineaire-slider-60-cm-i1400-t14800.html
  • 2 × MGN12 Rail 40cm https://www.123-3d.nl/123-3D-MGN12H-Lineaire-slider-40-cm-i989-t14800.html
  • 7 × TMC 5160
  • 2 × Slice Engineering Mosquito Magnum https://www.bondtech.se/en/product/mosquito-magnum/
  • 2 × Bondtech BMG M https://www.bondtech.se/en/product/bmg-m-extruder/
View all 14 components
