The remote control is connected to the external unit, from which it receives power and data, by twin core cable. It can display the following data:
- Heating mode
- DHW mode
- Outside air temp
- 'Inside' air temp (measured on the remote controller itself)
- Compressor on/off
- Pump on/off
- Fans on/off
- Date/Time (RTC on the remote control itself)
- Circulating water return temperature
- Compressor frequency
- Refrigerant discharge temperature
- Power consumption
- Fan speed
- Defrost temperature
- Water pump speed
- Refrigerant suction temperature
- Circulating water discharge temperature
Not too bad! (but more variables to decode...)
DC voltage on the cable is ~12V, and the manual indicates that there is no specific polarity required for the remote.
Internally, the remote includes an R8C/L3AC MCU (which has many IO ports, A/D and D/A converters, and an LCD driver), a T6B70BFG (Toshiba, communications IC), a 5V regulator, and a full bridge rectifier IC.
The T6B70BFG reads/imposes a 250kHz 'sine-ish' wave over the DC supply:
Sigrok Analogue 'input' to the T6B70BFG
Sigrok digital 'output' from the T6B70BFG
Having my circuit read the analogue side would be less invasive, but may be more difficult.
