1Print necessary parts
At a minimum this should be the glasses or visor and two struts. The full configuration requires the glasses or visor, four struts, and stabilizer
2Attach two or four struts to glasses or visor
The struts friction fit onto both the glasses and visor. A drop a glue can be added for extra security.
3(Optional) Attach stabilizer bar
Attach a stabilizer to add rigidity
4Attach plastic wrap to the frame of the glasses or visor
A sheet of 14"x11.5" (standard plastic wrap width) can be used. The sheet can be punctured over the pointy frame ends to be secured, and then wrapped over the frame onto itself. Tape or other adhesives can be added for extended use.
5Add elastic or string to visor
Some sort of string or elastic fastener is needed to secure the visor to the head
Connor Yamada
