The basic PC Gameport provides connection for up two controllers with 2 axes and 2 buttons each.
When in idle, both axes shall present half of the potentiometer value (50K). When the stick LEFT and UP the potentiometer of X and Y axes shall respectively present a resistance close to zero. On the opposite side, when the the stick is RIGHT and DOWN the resistance should be close to 100K.
To measure the potentiometers using the Arduino, there are two possibilities:
- Adding a capacitor on each axis and measuring the time just like the PC does.
- Using the ADC altogether with external pulldown resistors.
First method provides a more precise method but requires a protection resistor and a timing capacitor for each axis.
void samplePCjoystick() {
static volatile uint16_t counter=0;
uint8_t sample;
a1X=0; a1Y=0; a2X=0; a2Y=0;
releaseCaps();
delayMicroseconds(5);
counter = 1024;
do { // sample inputs with time constant loop
sample = ~PINC;
delayMicroseconds(3);
a2Y+=sample & 1;
sample>>=1;
a2X+=sample & 1;
sample>>=1;
a1Y+=sample & 1;
sample>>=1;
a1X+=sample & 1;
} while (--counter);
// reset caps
holdCaps();
The second method requires only a pull down resistor but provides a non-linear curve that must be linearized.
int8_t PCJoy::_adcTo100(uint16_t adc)
int32_t retval = ((int32_t) 79794 / adc) - 178;
if (retval < -99)
return -99;
else if (retval > 99)
return 99;
else
return retval;
That will return a value within -99 to 99.
